Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Malibu
Old 03-14-2009, 07:38 PM   #1
jandj1999
jandj1999 Normal reputation
Passlock 2 bypass help
I have a 1999 malibu with the wonderful passlock 2 system.I am looking for information to bypass the system completely.I CAN NOT start the car so the method of testing the ohms is not possible.I am sure there is a way to bypass it without having to be able to start the car.Any help would be greatly appreciated.
jandj1999 is offline   Reply With Quote
Old 03-15-2009, 12:23 AM   #2
discnik
discnik Normal reputation
Re: Passlock 2 bypass help
Try this site, it should give you what you are looking for.
http://vats.likeabigdog.com/
discnik is offline   Reply With Quote
Old 03-15-2009, 09:48 AM   #3
slls
slls Normal reputation
99 has passlock not passkey.
slls is offline   Reply With Quote
Old 03-15-2009, 01:43 PM   #4
jandj1999
...............Let me add this to the story.I bought the car,did not run,abandonded vehicle.I found out the BCM was bad because of multiple things like,no interior lights,buzzer or gas gauge.I replaced the BCM with a used one.Same exact part number.Now it has codes po1630 and po1631.Tried the KOEO to reset VTD system (multiple times).It continues to set the same two codes and no start.I am wondering if the BCM and ECM/PCM have to be replaced together in order to work.Just a guess,somebody has surely had this problem before.
Old 03-15-2009, 02:48 PM   #5
brcidd
brcidd's Avatar
brcidd Normal reputation
When you replace the BCM, regardless of part number- you can rest assured the BCM must be re-programmed with a Tech II scan tool with a techline terminal link to enter all the body functions and programming codes. I just read this from the service manual. Do you have the manual? Are you sure the original BCM was bad? Looks like you need to find someone who can program it for you..
Automotive A/C Engineer with:
'95 Chev 3500, 454 Dually Crew Cab- 145k miles- Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone- blown head gasket
'92 Chevy Lumina Van 3.8L 264k miles
'86 GMC S-15 - 2.8L 154k miles
'86 Buick Park Ave 3.8L 199k miles- my daily driver
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles- my high school car!!
All but the Camaro and Firebird are white....
brcidd is offline   Reply With Quote
Old 05-23-2009, 05:11 PM   #6
earlycuyler
earlycuyler Normal reputation
I've been reading about this and there's a long thread and everyones talks about soldering a resistor between the ignition wires but I can't find a write up.
earlycuyler is offline   Reply With Quote
Old 05-23-2009, 05:32 PM   #7
earlycuyler
I did find this link if it helps anyone
http://members.tripod.com/~autosecurity/PASS1.html
Bookmarks
Google
Web AF
