2003 pontiac grand am gtlilforyou 03-14-2009, 04:26 PM i recently changed my front drivers side bulb with replacement part 9007 and to no avail its very dim did i buy the right bulb?:confused: saturntech 03-14-2009, 05:26 PM 9007 sounds like the right bulb, bring it back and get a new 1, sounds like you got a faulty bulb, try that for now and it will rule that out. doctorhrdware 03-14-2009, 07:34 PM Could be a bad bulb or you could have low voltage to the socket. I would also measure the voltage you should have 12Vdc at the socket. J-Ri 03-15-2009, 08:43 PM Could be a bad bulb or you could have low voltage to the socket. I would also measure the voltage you should have 12Vdc at the socket. I know what you mean when you say 12v, but to clairify for someone who doesn't know: You should have the same voltage across the bulb as you do across the battery terminals within .25v xeroinfinity 03-16-2009, 05:13 PM Welcome to AF lilforyou !! Is it the same bulb as on the other side ? If its not the same this may be the problem. :2cents: ps- SYLVANIA SILVERSTAR are the best ! Automotive Network, Inc., Copyright ©2012
