'05 Tacoma Engine CodeJMBacker 03-13-2009, 06:54 PM My '05 Tacoma X-Runner's check engine light is on. I went to the local parts store who read the code and told me there were two codes for "Low Threshold". They said this would be an issue with the catalitic converter. Does anyone know where I can find a description of the codes? For free? I could get the code# if it would help. Has anyone else seen this problem or know what it may take to fix it? Thanks for the help. Flash75 03-14-2009, 08:07 AM You can find code information at the manuals link at the top of this forum. Look at; Combined Toyota Factory Truck Maintenance Manuals. Follow the link and you will find download or on line versions of your truck shop manual. You will have to spend some time searching to find your specific codes. The diagnostics will say what the possible causes may be and how to test or troubleshoot the suspect parts. You may find some tests will require the use of some test equipment not in the average owners tool kit. The mauual should help you find the cause of your problem. Clifton vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
