1981 Chevettesamprix 03-13-2009, 09:35 AM Does anyone know if it is possible to remove the oil pan with out pulling the motor? leekelvin 12-08-2009, 04:14 AM Yes,but oil pan gaskets don't leak very often its usually a front or rear crank shaft that is misdiagnosed. samprix 03-12-2010, 03:55 PM The pan gasket wasn't leaking. I wanted to replace the oil pump because I thought it was shot. Turns out the person who replaced the head plugged up the oil galleries leading to the cam house with RTV. Runs good now. Darylellis 03-03-2011, 11:56 AM Yup i am sure you can change the oil pump. or else you can get it replaced completely that should work fine. Automotive Network, Inc., Copyright ©2012
