Car cutting off randomlycaramel4 03-13-2009, 02:30 AM lately my car has been cutting off randomly and jerks . and the check engine light is on, but it has been for months. it only shut off sometimes when i slow down or when i'm idle (like at a light or something). when it 1st happened earlier this yr. i was told i probably put some bad gas in my car and to get a gas treament but now its happening more frequent, seemingly everytime i put gas in my car. i'm a student so money is tight and its really scary not knowing when your car is gonna shut off or were you'll be...any advice Davescort97 03-13-2009, 06:02 AM Welcome to Automotive Forums. Here's what you need to do. Take it to the auto parts store, either Autozone or Advance. They won't charge you to put a scanner on your computer to find out what is wrong. It's called pulling a code. Once you know what the code is, come back to Automotive Forums and let us know. Then, we can tell you how to fix your car. caramel4 03-15-2009, 01:27 PM ok. i went to advance auto and they did a diagnostic test and they only said that i probably needed a gas treatment. so i bought a ten dollar gas treatment and it still didnt work. i then went to a mechanic and he said my vacuum hose was slashed so i had it replaced but the problem is still there even thought the check engine light is now off. so is it possible i need a new fuel filter. it stalls at lights, when i slow down, and turns off when i sit for a while, and now white smoke is coming from my exhaust beyondloadedSE 03-15-2009, 08:24 PM ok. i went to advance auto and they did a diagnostic test and they only said that i probably needed a gas treatment. so i bought a ten dollar gas treatment and it still didnt work. i then went to a mechanic and he said my vacuum hose was slashed so i had it replaced but the problem is still there even thought the check engine light is now off. so is it possible i need a new fuel filter. it stalls at lights, when i slow down, and turns off when i sit for a while, and now white smoke is coming from my exhaust So...what was the code they gave you? vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
