Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Monte Carlo
Old 03-11-2009, 03:36 PM   #1
j cAT
j cAT Normal reputation
98 3.8L upper intake designed to fail
recently my daughters intake manifold required replacement because the plastic upper intake manifold cracked at the EGR port...
this is another example of poor quality , and a designed to fail position that GM has been doing for years...
for GM it's 100years of existance soon going to be RIP...
if you experience this ,,,basicly exhaust gases/noise exits the air intake ...also the MAF will show a bad reading ....
j cAT is offline   Reply With Quote
Old 03-11-2009, 03:39 PM   #2
maxwedge
A990 racer
maxwedge Normal reputation
Re: 98 3.8L upper intake designed to fail
I don't know here, I just did my daughter's 98 LTZ, 220k miles, cost me 150 dollars what's the big deal about this after 11 years? Ford has had their issues with this cracking manifold deal although only vacuum leaks are created.
maxwedge is offline   Reply With Quote
Old 03-11-2009, 03:46 PM   #3
j cAT
this problem has been around for a long time and she was fortuate to get this amount of useage before it cracked...this is true...
still it is a failed design...and they should have used a different solution..
point here is if you consider this vehicle this is something that IS gonna fail...no way around it...
Old 03-11-2009, 04:28 PM   #4
Blt2Lst
Blt2Lst's Avatar
Blt2Lst Normal reputation
Sure it would cost you and I $150 because we can do the work ourselves.
But what about the other people who have to pay $700 - $1000 for this repair. Just a big money generator for the dealer and the repair shops.
I have read many posts about this problem on the GM 3.8's and I believe there is a class action suit pending.
I try real hard to continue to like GM products but when you hear about all the horror stories about quality issues it make me wonder.
1989 Caprice Classic Wagon
307 4bbl, 200R4 w/Shift kit, Flowmaster 50 series muffler, Hotchkiss sway bars, KYB Shocks.
1989 Mustang LX 5.0 5sp convertible
1996 Suzuki RMX250
"Don't worry about what I just said, just do what I told you" Beetlejuice
Blt2Lst is offline   Reply With Quote
Old 03-11-2009, 07:53 PM   #5
drdisque
drdisque's Avatar
drdisque Normal reputation
Send a message via AIM to drdisque
cmon dude, don't blame GM for having a minor problem on an 11 year old car.
Dr. Disque - 2007 Mazda 6-S 5 Door
drdisque is offline   Reply With Quote
Old 03-11-2009, 10:41 PM   #6
Blt2Lst
Blt2Lst's Avatar
You call that a minor repair?
My problem with GM on this issue is that they misled the public and did not take responsibility for their design flaw.
Everything more or less is gonna break at some point..
I still love my old Chevys
Al
1996 Suzuki RMX250
Old 03-11-2009, 11:25 PM   #7
RahX
RahX Normal reputation
They surrounded the egr inlet to the intake with plastic. On top of that, just on the other side of the plastic is coolant. So, after the intake cracks and leaks, it leaks coolant into the intake which can hydro lock the cylinders. I have replaced dozens of these intakes and I have yet to see any sustained damage other than having to replace the spark plugs on a few of them. Every car manufacturer has poor judgement and stupid design flaws. Whether or not they fix the problem in subsequent years really shows how much they want to improve the product. The 3.8L is one of the best engines that GM ever designed and a few minor problems would not ever deter me from recommending someone buy a car with one in it. The 3.1/3.4 and all subsequent engines of the same design are probably one of the worst GM has ever produced. I cringe when people tell me they bought a car with one in it.
RahX is offline   Reply With Quote
Old 03-12-2009, 12:02 AM   #8
Airjer_
Airjer_'s Avatar
Airjer_ Normal reputation
Agreed! 3.8 are pretty tough.
We replace a lot of those with the aftermarket plenums. Supposedly they are reinforced a little better in that area?
Airjer_ is offline   Reply With Quote
Old 03-12-2009, 10:22 AM   #9
j cAT
[quote=RahX;5932965] have replaced dozens of these intakes and I have yet to see any sustained damage other than having to replace the spark plugs on a few of them. quote]
the plugs required replacement because the MAP sensor was commanding the pcm/computer to inject max fuel into the cylinders because of the excessive intake manifold pressure..
the plugs where full of fuel....
the reason I have brought this out here is,, if the upper/lower intake manifold gaskets need replacing for your safety replace the upper intake....
if this blows on the hyway this could be dangerous...
Old 03-12-2009, 03:34 PM   #10
jrmy1krn
jrmy1krn Normal reputation
1. GM's BEST motor ever is prolly the 3.8/ 3.8sc., the only competion here would be a clasic small block imo.
2. GM is suffering because people want a cool looking car that will last for 200k miles. They dont want a plastic car with a shitty motor that you can bet will need work in 5 yrs.
3. Yeah true all cars have problems, but GM isnt allowed to make junky cars, only everyone else is.
4. And yeah maybe it is designed to fail, why else would you go to the dealership? They need a chance to sell you another junk car. They know that people dont want to rip into theyre cars engine and fix it themselves.
jrmy1krn is offline   Reply With Quote
Old 03-12-2009, 07:53 PM   #11
RahX
I've never had one blow out. They seep forever and 9/10 they fill the intake with coolant after you shut the engine off and you can't get it started the next morning because it is hydro-locked. The plugs i've changed probably needed to be changed anyway but they were nice and orange thanks to the dex cool.
Old 03-13-2009, 09:54 AM   #12
j cAT
all vehicles have defects....this is true..
the reason GM is going bankrupt, is because of how you ,,,,the vehicle owner , are treated when brought in for a warrantee repair....
dealerships are forcing the tech's to make half azz repairs , instead of properly repairing the vehicle in hopes that soon you will be beyond the warrantee period....
you think GM is so great ,,,,,,the stock price is less than two bucks buy a few hundred shares.....
Old 03-13-2009, 12:33 PM   #13
Blt2Lst
Blt2Lst's Avatar
Even at that price you will probably lose your shirt. Even with the stimulus injection of cash for GM, I don't see how the company can survive doing business as usual. I think the cash is really mean't to save jobs.
Pumping cash into GM is like putting a band aid on the hull of the Titanic to keep it from sinking, it ain't going to work. Maybe temporarily.
I hope GM survives, I want to see what the next Z-28 Camaro will be like.
1996 Suzuki RMX250
Old 03-13-2009, 01:27 PM   #14
j cAT
I own a 1984 camaro berlinetta , and was interested in this new camaro...saw on tv the testing and details....as displayed it looks good.
what happens after the bean counters f it up remains to be seen....IF GM lives ....
Old 03-23-2009, 07:48 PM   #15
emba129
emba129 Normal reputation
I have a 98 Montecarlo Z34 with this motor.. So far I havent seen this problem.. it has 95K miles.. How do I know this problem is starting to occur. Ive been watching the overflow bottle.
What should I watch out for?
emba129 is offline   Reply With Quote
Bookmarks
Google
Web AF
