Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Geo > Metro
Old 03-11-2009, 08:08 AM   #1
kdameron
kdameron Normal reputation
Brake sensor
My brake sensor has gone out. Does anyone have any directions or pictures on how to replace this part? I own a 1992 metro hatchback, manual transmission.
kdameron is offline   Reply With Quote
Old 03-11-2009, 11:09 AM   #2
Airjer_
Airjer_'s Avatar
Airjer_ Normal reputation
Re: Brake sensor
The brake "switch" for the brake lights or the level sensor that tells you your fluid is low?
Airjer_ is online now   Reply With Quote
Old 03-11-2009, 11:42 AM   #3
kdameron
Re: Brake sensor
It is the switch that is located right behind the brake pedal. Sorry about the confusion. Also, just to add, my window regulator has also broke so the window is being held up by duct tape until I can find a regulator some where. I'm striking out everywhere. I do have a buddy working on that for now.
Old 03-11-2009, 11:37 PM   #4
RossT
RossT Normal reputation
Re: Brake sensor
Here is the window regulator fix:
http://www.teamswift.net/viewtopic.php?f=2&t=17205
Very good helpful info. If the fix does not work, buy a used unit on e-bay.
RossT is offline   Reply With Quote
Old 03-12-2009, 08:20 AM   #5
kdameron
Re: Brake sensor
Thanks! I can't check it out at work, but I'll take a look tonight and reply back. I can say that I'm having problems removing the screws in the door handle area. I've tried using a screw remover bit but that's not working. The screw is completey rusted to the door mount.
Old 03-13-2009, 07:59 AM   #6
kdameron
Re: Brake sensor
I checked it out and very helpful!! Thanks for the info!! I'll update you when I get it fixed!
Old 03-16-2009, 08:18 AM   #7
kdameron
Re: Brake sensor
Well, I finally got the stop brake switch and it was the wrong one! I have a standard with a four frong switch but advance autoparts received a two prong stop brake switch. We saw a picture of a switch for an automatic and we think that they may it. Has anyone else come across this? As for the window regulator, I had to drill out several screws because of rust. The regulator doesn't look to bad, but I'm going to show it to a friend and get his opinion.
Thanks for the information guys and I will keep you updated
Old 03-16-2009, 10:51 PM   #8
RossT
Re: Brake sensor
Keep us postedt.
Did you read the part, in the link, on how to fix your regulator in a vise?
Bookmarks
Google
Web AF
