1994 caprice won't move!!
JFLO
03-11-2009, 02:55 AM
1994 CAPRICE CLASSIC 4.3L
I CAN CRANK THE CAR ACCELERATE IT IN PARK AND NEUTRAL BUT WEN I PUT IT IN ANY GEAR IT WNT ACCELERATE I CAN PUT IT IN REVERSE IT WILL ROLL BACK AND I CAN PUT IT IN DRIVE IT WILL ROLL FORWARD SLOW AS HELL (REPLACED FUEL FILTER,MASS AIR FLOW,MAP SENSOR, PLUGS AND WIRES) WAT COULD IT BE:banghead: (TORQUE CONVERTER???) (OPTI SPARK????) (FUEL PUMP)PLEASE HELP:confused:
j cAT
03-11-2009, 12:07 PM
when you put in gear is the engine rpm going up....when you hit the throttle...?
J-Ri
03-11-2009, 07:47 PM
Have you checked the transmission fluid level and condition? Usually if a transmission wont do anything it's fluid related.
JFLO
03-12-2009, 12:29 AM
no rpm is not going up at all
JFLO
03-12-2009, 12:31 AM
have you checked the transmission fluid level and condition? Usually if a transmission wont do anything it's fluid related.
checked transmission fluid level it was a little low added some fluid still the same and fluid is normal color with no burnt smell
j cAT
03-12-2009, 10:05 AM
remove the upstream O2 sensors and see if the problem lessens,,,,physically remove.....if so the cat is /or exhaust is plugged..
also if you have a severe exhaust leak near the engine the KS may retard the timing severely.....
check the KS connectors for security and corrosion....
