94 s10 blazer 4.3 high oil pressurechevyshitsonford 03-06-2009, 07:20 PM usually around 30 35 psi but now for the past week it runs at 40 45 . never ran this high before and if it did it would go back down after wharm up. last oil change was about 4000mi ago first time i used synthetic blend but this problem just started. found some somewhere online about the remote oil lines could be the cause for the high pressure. any other ideas? can u easly test oil relief valve? also Orangeish brownish gunk in radiator on top and coating in side even after i replaced leaking radiator flushed many times keeps cumin back. other note put fuel saving chip in 2 weeks ago made engine run smoother, and added new intake with filter, doubt the intake has any thing to do with it , maybe the chip? MT-2500 03-07-2009, 09:56 AM usually around 30 35 psi but now for the past week it runs at 40 45 . never ran this high before and if it did it would go back down after wharm up. last oil change was about 4000mi ago first time i used synthetic blend but this problem just started. found some somewhere online about the remote oil lines could be the cause for the high pressure. any other ideas? can u easly test oil relief valve? also Orangeish brownish gunk in radiator on top and coating in side even after i replaced leaking radiator flushed many times keeps cumin back. other note put fuel saving chip in 2 weeks ago made engine run smoother, and added new intake with filter, doubt the intake has any thing to do with it , maybe the chip? Do not tell anyone. Fuel chips are illegal. Chip has nothing to do with oil pressure raising. Check fuel pressure with a manual oil pressure test gauge. Post back actual pressure. djd99 03-07-2009, 12:30 PM Do not tell anyone. Fuel chips are illegal. Chip has nothing to do with oil pressure raising. Check fuel pressure with a manual oil pressure test gauge. Post back actual pressure. I think mt was trying to say check your oil pressure with a manual oil pressure gauge. You could have a bad oil pressure sending unit or a bad gauge. Ya and the accessories you put on would have no effect on oil pressure. Only your oil pump controls pressure. chevyshitsonford 03-07-2009, 10:22 PM I think mt was trying to say check your oil pressure with a manual oil pressure gauge. You could have a bad oil pressure sending unit or a bad gauge. Ya and the accessories you put on would have no effect on oil pressure. Only your oil pump controls pressure. first off thanks will do it problem continues after oil change. and what were u saying that's illegal , fuel chip? its a performance chip that's supposed to save me gas. could u explain your self MT-2500 03-08-2009, 10:11 AM first off thanks will do it problem continues after oil change. and what were u saying that's illegal , fuel chip? its a performance chip that's supposed to save me gas. could u explain your self Adding a chip is tampering with you federal emissions. Any time you tamper with your emissions and drive it on a federal funded highway you are subject to jail time and big bucks fines. Covered under.in the EPA clean air act of 1990. http://www.epa.gov/air/caa/title2.html#iia http://www.epa.gov/air/caa/ http://www.epa.gov/air/caa/caa203.txt http://www.epa.gov/air/caa/caa205.txt http://www.epa.gov/otaq/recall.htm http://www.epa.gov/air/caa/ http://www.epa.gov/air/caa/title2.html#iia EPA Laws sections. Automotive Network, Inc., Copyright ©2012
