Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Toyota > 4Runner/GX470
Old 03-06-2009, 04:01 PM   #1
jpshreve
jpshreve Normal reputation
Question belts on 1996 4Runner
The belts are frayed on my 1996 4Runner. The engine is a 5VZ-FE. How do I loosen the belts to remove them?
Thanks
jpshreve is offline   Reply With Quote
Old 03-06-2009, 07:13 PM   #2
Brian R.
Resident Chemist
Brian R.'s Avatar
Brian R. Normal reputation
Send a message via Yahoo to Brian R.
Re: belts on 1996 4Runner
To remove them, cut them off. To install and adjust tension on new belts work from engine forward, alternator, A/C, then P/S:
Alternator - Pivot bolt is on top, tensioner is on bottom middle of alternator facing driver's side wheel well. Tension lock nut is in front on bottom. Both pivot bolt and lock nut must be loosened to move alternator with tensioner. Loosen tensioner/install belt/tighten tensioner.
Tighten:
Pivot bolt 38 ft-lbs
Lock nut 25 ft-lbs
A/C unit has idler pulley. Remove the skid plate to gain access from bottom. Loosen idler pulley lock nut (center of pulley) and move pulley in with adjusting bolt (driver's side bottom). Tighten idler pulley lock nut to 22 in-lbs/install drive belt/adjust belt tension.
Tighten:
Pulley lock nut 29 ft-lbs
Install skid plate
Power steering unit:
Same description as alternator except facing passenger side. You can see the P/S tensioning unit from the top. You have to turn the pully to get access to pivot bolt.
Tighten:
Pivot bolt 32 ft-lbs
Lock nut 32 ft-lbs
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Brian R. is offline   Reply With Quote
Old 03-07-2009, 12:00 PM   #3
jpshreve
Brian,
Thanks! It's all beginning to make sense. I'll get right on it.
Old 03-09-2009, 12:10 PM   #4
jpshreve
The new belts are on, truck runs fine. Thanks again for your help.
Old 03-09-2009, 01:37 PM   #5
Brian R.
Resident Chemist
Brian R.'s Avatar
You're welcome
Bookmarks
Google
Web AF
