96 Intrepid 3.5l fans always running89BirdMan94 03-04-2009, 10:26 PM Currently purcahsed a 1996 Intrepid for a pretty unbeatable price car didnt run i tooke it apart it was jsut the tension pulley and the water pump shot so no timing. fixed that fired her up runs wut id expect for 200 dollars and a 130 fix however the fans come on when car starts and never shut off wut could be keeping them on? ne1 tempfixit 03-04-2009, 11:01 PM Have you checked the hi and low fan relay's under the hood?? ricebike 03-05-2009, 12:30 AM having the AC/ defrost mode can keep them running as well... 89BirdMan94 03-05-2009, 12:37 AM yes ive checked and even replaced the relays still nothing. defrost etc is off during this tempfixit 03-05-2009, 08:49 AM Try unhooking the A/C pressure transducer switch, see if that helps. Could also be ECT. Check this thread out: http://www.automotiveforums.com/vbulletin/showthread.php?t=897047&highlight=coolant+fans+running 89BirdMan94 03-10-2009, 05:16 AM ok so this worked for a day then bam fans are on i am still getting 2 codes coming up low and hi fan related tempfixit 03-10-2009, 10:08 AM ok so this worked for a day then bam fans are on i am still getting 2 codes coming up low and hi fan related I assume you mean disconnecting the tranducer, right? Have you tryed disconnecting battery for like 5 minutes or removed the IOD fuse to reset the computors? What code numbers are you getting?? Have you checked the ECT? 89BirdMan94 03-10-2009, 03:50 PM I will post the codes tonight when i rehooke the comp up i havent unhooked battery yet ima try that first. and yes i was reffering too unplugging the transducer 89BirdMan94 03-10-2009, 07:03 PM Codes coming up are P0172 sys to rich(Bank1) ne suggestions on this? P1490 Low Speed system fan relay circuit fault(i even replaced the relays) P1489 High Speed System fan relay control circuit fault(replaced Relay Still notta) unhooked the ac transducer still fans are on tempfixit 03-10-2009, 10:54 PM This is out of a 2002 Intrepid FSM but should pretty much pertain: Coolant fans continually running; Possible causes, 1-Fan Relay, PCM or Engine Coolant temperature sensor possibly defective. 2- Check for low coolant level. 3-A/C pressure transducer defective. According to FSM these compotents effect fan control: 1-A/C pressure transducer 2-PCM 3-Coolant temperature sensor 4-Intake AIr Temperature sensor 5-Output Speed Sensor 6-Transmission Oil Temoperature Sensor putput to PCM. P0172----1/1Fuel System Rich///A rich iar/fuel mixturehas bee indicatedby an abnormally lean correction factor. P1489-Open or shorted condition detected in the control circuit of the high speed radiator fan control relay. P1490- Open or shorted condtiondetected in the control circuit of the low speed radiator fan control relay. Do you have relays for radiator fan in the Power Distribution Center and between the cooling fans?? Have you checked the ECT?? Automotive Network, Inc., Copyright ©2012
