Re: 93, Vandura won't startalbee9 03-04-2009, 08:25 AM Hi ppl It's been a while ( the saga continues ) Well I'm back and after almost year I'm back tiring to get the Vandura running . In my last post My problem started when I started getting black smoke from the exhaust so i thought change the spark plugs which were very fowled just to get it home . but still black smoke so i changed the fuel injectors still hard to start so to make a long story short . I have replaced : the spark plugs,the wires distributor,rotor, the ignition coil,EGR solenoid ,and fuel injectors and it still won't start . So I'm thinking it maybe it's the Fuel Injector Pressure Regulator because i get a stream of gas not a mist like it should be . I'd like to know if I'm right Please help thank you for your time maxwedge 03-04-2009, 04:02 PM Have you tested the fuel pressue, got good spark?, will it start spraying starting fluid into the intake. All basic diagnostic steps. albee9 03-04-2009, 05:01 PM Have you tested the fuel pressure, got good spark?, will it start spraying starting fluid into the intake. All basic diagnostic steps. I did all the checks every thing checks out the only thing left is to check the fuel pressure. If the pressure is too high then what ?? duke350 03-04-2009, 05:50 PM I am not sure what a Vandura is but if you have TBI and it is streaming instead of spraying, it sounds like the injector is dirty/bad. Did you use new or used ones? If the fuel pressure is to high then you either have a blocked return line or a bad regulator. albee9 03-05-2009, 02:28 PM I am not sure what a Vandura is but if you have TBI and it is streaming instead of spraying, it sounds like the injector is dirty/bad. Did you use new or used ones? If the fuel pressure is to high then you either have a blocked return line or a bad regulator. DUH ?????? How dumb of me not to think about a blocked return line . Thank you all for your help Automotive Network, Inc., Copyright ©2012
