Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Volkswagen > Jetta/Vento/Bora > '91 - '96
Old 03-03-2009, 08:41 PM   #1
yarrowman
yarrowman Normal reputation
95 Jetta Gas Gauge Problem
I have recently been given a 1995 Jetta III GLX and too my surprise I found that the gas gauge does not registered. I have looked at other forum posts and seen that it is probably a problem with the fuel level sender unit. I found it in the trunk and used a wire to connect the two small wires together but nothing happened. What is the next step I should take, and what are the most likely problems?
yarrowman is offline   Reply With Quote
Old 06-02-2009, 10:16 PM   #2
Davez69gto
Davez69gto Normal reputation
Re: 95 Jetta Gas Gauge Problem
If you have the tank off i would pull out the part that reads the fual and then put a multimeter to it reading the resistance. Then as you move the lever on the fuel level sending unit the resistance should change.
Davez69gto is offline   Reply With Quote
Bookmarks
Google
Web AF
