Originally Posted by draasch
there is no alarm on this truck. i have squared the horn issue away for now. where would i find the switch that you are talking about. it does seem like it only does this when its cold out or if the truck sits for a while.............could it be the sol on the starter????? cant get it to act up with two people around to check the starter.....
with no alarm system the problem still can be the ignition switch or starter solenoid/motor...
because it acts up after inactivity I would check the connections at the starter...remove clean and continue to operate until it fails more often..
when in the fail to start mode do you hear the starter solenoid click ??? IF yes then it would most certainly be the starter/connection at starter especially ,,, the connection nut that connects the solenoid to the starter motor,,,,as I have found this nut to be loose on out of the box new statrers..
this loose nut had me going for a while,,,after that I always secure all the starter connections....remove/clean reinstall nut///paint was on surface as well...small wire brush to clean ..etc,,,,
