Re: 98 Contour Codes P1131 and P0401
Originally Posted by Airjer_
disconnect the vacuum line to the EGR valve. Does the symptom improve? It is possible that the DPFE sensor is stuck low. When you accelerate the EGR is commanded depending on the load. If the PCM doesn't see the change in the DPFE readings it will try to command even more EGR. This can cause all kinds of drivability complaints including the one you have described.
FWIW, the EGR is used when cruising only and is closed during acceleration. If by "demanding more of the EGR" you mean, it "opens more", this is simply not true. During acceleration, the EGR is used less to none.
I would agree you have something going on with the EGR system.
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
