Re: power steering noise
There's a tsb:
SERVICE TIP - POWER STEERING OIL PUMP
WHINE NOISE
DESCRIPTION:
Before replacing a power steering oil pump for a "whine" noise condition, check the oil
pump reservoir filter screen for contamination. If the filter screen at the bottom of the oil
pump reservoir is clogged, it may cause the pump to aerate and cause a "whine" noise.
If the filter screen is clogged, replace the reservoir and reconfirm the condition.
The photo below shows the location of the screen in the reservoir.
NOTE: For proper inspection of the screen, it may be necessary to empty the
power steering oil pump reservoir.
