Re: Noise from the Left front
It could be one of several things but probably not the tie rod end.
The first place to look is tire clearance. Are you running oversize wheels and/ or tires?
Check to see if they are rubbing somewhere (usually the inner fender cover).
Check the inner fender covers and the engine under covers. Sometimes they can break at the mounting points and get in the way of the tire.
After checking all of that, the next steps would be to check the brakes, and then the axles.
Of course, you would replace as necessary.
Good luck!
