1988 Ranger (2.9) A4ld slipping in drive and overdriveJSRanger 02-21-2009, 09:51 AM 1988 Ranger (2.9) A4ld slipping in drive and overdrive. Does this usually require a rebuild/replace or could the computer, or an electronic part be a possibility? How about vacuum? Thanks for any help. rhandwor 02-22-2009, 08:58 AM Pull the dip stick and if if the fluid has a burnt smell it needs a rebuild. JSRanger 02-22-2009, 11:23 AM I did change the filter. The fluid I drained did not smell burnt. rhandwor 02-22-2009, 03:05 PM I would get a couple of estimates at some independent transmission shops I think the right person could fix it but most will quote a complete rebuild. JSRanger 02-23-2009, 04:33 AM Thanks for your replies. I did have this transmission rebuilt about 40,000 miles ago. From what I have read online the a4ld does have problems. What's a good manual transmission that will bolt up to the 2.9 engine if I decide to do a swap? vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
