Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Astro > M Bodies
Old 02-20-2009, 11:26 PM   #1
mrfixit44
mrfixit44 Normal reputation
97 astro van engine code po 300
my van is still showwing two codes,both po 300,missfire multiple cylinders,under power,about 55-65 mph,it gets sluggish,at idle,not missing too bad,i replaced the cap and rotor,about 2 months ago,and used my obdII scanner to turn of the check engine light,ran fine,now it just started comming on again,what now?? thanks for any tips,you can e mail me @ rascal9094@yahoo.com..
mrfixit44 is offline   Reply With Quote
Old 02-21-2009, 11:37 AM   #2
Blue Bowtie
Registered Offender
Blue Bowtie's Avatar
Blue Bowtie Normal reputation
Re: 97 astro van engine code po 300
Welcome Aboard!
If you think the cap and rotor are intact, check the coil and secondary wires. If you suspect the cap has broken down already (not uncommon with aftermarket caps) you can meg between the various terminals to check for leakage.
Blue Bowtie is offline   Reply With Quote
Old 02-21-2009, 12:42 PM   #3
five04ever
five04ever Normal reputation
mrfixit44 - I had a simular problem about a week ago (same 300 code) and left my 99 Astro parked all week without checking... Go to start it today and no start... What I found right off the bat is that I have spark shooting down the coil wire right at the coil connection. I swapped wires and same exact problem. I then pulled the wire off the coil and the spark was going crazy on the top/side (spout?) of the coil... I expect my coil is bad... My problem is that I'm not sure what caused this?????
five04ever is offline   Reply With Quote
Old 02-21-2009, 02:20 PM   #4
mrfixit44
thanks for the help,the fun part is tearing into the engine cover of which is part of the dash to work on it,not fun,plugs are hard to change also,have a good one.
Old 02-22-2009, 07:43 AM   #5
Blue Bowtie
Registered Offender
I feel your pain:
Bookmarks
Google
Web AF
