Pcv valve on 2004 Dodge Caravansamtheman22 02-17-2009, 11:19 AM Anyone know where the pcv valve is located on a 2004 Dodge Caravan 3.3L. Manual advises to change, but does not show location and I can't find, :frown: Thanks Mrbizness1 02-18-2009, 06:21 PM this is a photo of a 98 3.3 pcv location. odds are that the pcv hose will need replacement also. they get dry rot from engine heat. http://i142.photobucket.com/albums/r100/mrbizness1/PCVValve9833.jpg DirtRaceFan79 02-18-2009, 11:16 PM Anyone know where the pcv valve is located on a 2004 Dodge Caravan 3.3L. Manual advises to change, but does not show location and I can't find, :frown: Thanks It is on the rear Valve cover. Very hard to see and sometimes hard to get out. The PCV hose complety covers it. It just pushes straight in so you have to get pliers to get it out, and you will likely damage it doing so, so make sure you have a new one before you pull it out. Cntrysthbst 02-28-2009, 10:38 PM and be careful of dirt buildup around area when taking off..before pulling it out all the way it might help to take a tooth brush and clean it..or air gun..to prevent any dirt from falling inside valve cover..3.3 and 3.8 2001 to 2007 are on rear valve cover..same with T&C. Automotive Network, Inc., Copyright ©2012
