Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Dodge > Dakota
Old 02-16-2009, 04:53 PM   #1
jam-flstci
jam-flstci Normal reputation
94 dakota trans problem
my stepsons dakota has developed some sort of transmission problem any ideas would be helpful .
1994 dakota v6 auto
I've had the rubber hose going to the trans cooler fail twice ( passenger side both times ) First time the hose was old with signs of dry rot , replaced with new topped off the fluid every thing ran fine.
A day or so later the same hose burst again , bad hose ?
Replaced the hose a second time , top off the fluid everything worked ok . he drove the truck about 50 miles no problems .
The next day he drives about 10 miles then the truck wont move in any gear , after letting it sit for a few minutes start it up and it would work fine for a few minutes did this several time till I could get it off the main road . Any Ideas
Thanks Jared
jam-flstci is offline   Reply With Quote
Old 08-09-2009, 06:18 PM   #2
dakota4x4
dakota4x4 Normal reputation
Send a message via Yahoo to dakota4x4
Re: 94 dakota trans problem
i got a 93 dakota, and the mechanic that rebuilt it, said that my year tranny was messed up ,it needed a transmission cooler added ,and theres a sensor in the line he had to bypass. that back when they made the trannys in those years ,that they never fixed the problem just quit making the trucks. i got the 4x4 model. if thats it.
dakota4x4 is offline   Reply With Quote
Old 08-10-2009, 04:31 AM   #3
din365
din365 Normal reputation
1994 dakota v6 auto
Thanks Jared
My brother had a similar problem with his 93 chrysler dynasty(minus the blown hoses). I wouldn't go into drive unless it was warmed up and in neutral.
The solution? there was a bad solonoid causing the problem.
Also, if you're changing the line, make sure you don't put the line on too tight, because that can cause it to blow out on you, too.
so just check your solonoid, and check to make sure you didn't overtighten the line.
din365 is offline   Reply With Quote
Bookmarks
Google
Web AF
