2000 intrepid no startoldschool2000 02-10-2009, 02:53 PM car would not start one morning unplugged cam positioning senser and car started replaced senser and started car a little harder to start now have to hit throttle while cranking to start also troble code P0340 no cam signal at pcm is on cant clear code w/ scanner or manually engine light on tempfixit 02-10-2009, 09:07 PM By manually do you mean that you disconnected battery for 3-5 minutes to clear codes? Which engine? mileage Have you checked fuel pressure and fuel pressure regulator. I had a 95 voyager with a 3.3 engine that the accelerator had to be to the floor to start and it was the fuel pressure regulator not sure if it would pertain to yours but worth checking. oldschool2000 02-14-2009, 04:59 PM By manually do you mean that you disconnected battery for 3-5 minutes to clear codes? Which engine? mileage Have you checked fuel pressure and fuel pressure regulator. I had a 95 voyager with a 3.3 engine that the accelerator had to be to the floor to start and it was the fuel pressure regulator not sure if it would pertain to yours but worth checking. 2.7L 110,000 MI YES MANUALLY TRIED TO CLEAR BY DISCONNECTING BAT FOR 3 MIN DID NOT CHECK FUEL PRESSURE YET i WAS MISTAKEN ABOUT HAVING TO TOUCH THROTTLE TO START I JUST HAVE TO CRANK ENGINE FOR ABOUT 15 SECS B4IT STARTS HAVE TOACCELERATE SLOWLY OR IT FALLS ON ITS FACE AND RECOVERS WHEN U LET OFF GAS (BIG FLAT SPOT) OTHERWISE IT RUNS FINE EXCEPT FOR CHECK ENGINE LIGHT ON W/ ERROR CODE FOR CAM POS SENSER tempfixit 02-15-2009, 12:25 AM Sounds like a bad fuel pump or fuel pressure regulator. Get a fuel pressure tester on it on and post readings. When you disconnect the fuel pressure regulator hose there should not be any gas in line and the pressure should increase by about 10psi. Automotive Network, Inc., Copyright ©2012
