Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Toyota > Pick-Up
Old 02-10-2009, 12:41 PM   #1
Mike916
Mike916 Normal reputation
1990 toyota pickup 3.0evz v6
engine crank but wont start...i have already changed alternater, battery, starters good, all timing belt, a brand new distrubiter and a rebuild engine a few days ago but somehow it crank but wont start....b4 i swap the motor while trying to start it, there seems to be some smoke coming out of the wiring harness on top of the engine....could that be the problem? any suggestion....any help would be greatly appreciate... thank you
Mike916 is offline   Reply With Quote
Old 02-10-2009, 01:40 PM   #2
fourwd1
AF -Advisor
fourwd1's Avatar
fourwd1 Normal reputation
Re: 1990 toyota pickup 3.0evz v6
You have a lot of things going on at once that could be causing problems.
The smoking wiring harness for one, it should have been troubleshot and fixed when it began, before you pulled the engine.
Now with a new engine, it could be the old wiring harness problem, any number of things with the rebuild, the install of the new engine, etc ...
Have you done the basics like check for fuel and spark ?
- - as seen in FOUR WHEELER magazine July 06 and OFF-ROAD magazine Feb 07 - -
84 4Runner - ARBed 5.29s F&R, 4.7 & 2.28 t-cases, Chevys, AP x-over, BudBuilt x-member, 2" drv trn lift, 36" TSLs, 30 spline Longs
80 something p/u - Buick 231 V6/TH-350 trans, Holley 4 bbl, Weiand intake, dual batts, dual tanks ...
89 4Runner - stock
fourwd1 is offline   Reply With Quote
Old 02-11-2009, 11:47 AM   #3
Mike916
yea b4 the engine swap, it got good spark, good fuel and there a check engine light. when i read the code and look at the haynes manual book it say the problem was that it doesnt had enought air flow so i change the mass air flow sensor n it still not working. also i check the compression the 1st time its was175 and then i recheck it agian a week later it went down to 65 on 4 piston and 2 are at 25 thats why i decide to change the motor....i notice how on the fuel injector it has two pin or something that when u check it with the light only one side suppose to light up right? on mine both side lights up....any suggestion on where to go from here? and thanks for your help....
Old 02-17-2009, 08:17 AM   #4
sandman608
sandman608 Normal reputation
have you replaced the wiring harness yet if not you should call your local salvage yard & see if the have one they have not hacked all up & maybe look @ replacing it then find out where your short is so you dont fry another harness.Do you have a body lift kit or suspension lift have you been in a fender bender,just some area's to check for a pinched or stretched wire's
sandman608 is offline   Reply With Quote
Old 02-17-2009, 08:20 AM   #5
sandman608
check the Igniter Box
Old 02-17-2009, 01:37 PM   #6
Mike916
no i haven't replace the wire harness yea...and i try all the recycle yard and salvage yard....they all have automative only....so i decided to take it out and check all the wire myself but nothing seem to be wrong....no cut wire, no burn, i even check the ecu looks as good as new....some people told me that if i got a lose speaker wire or deck wire that somehow its touching something the car wont start either is that true cuzz i just remember i had a speaker on the passanger side that i just left it hanging there....oh and my cars hasnt been raise yet it still stock everything.....
Old 02-27-2009, 03:37 AM   #7
Mike916
sorry guys but i think i ran into another problem.....now that i finally got the car to start it runs wierd....like on the street it runs fine as if u cant tell a different but when you run on the highway it runs really weak even though i floor it it still takes a long time to get to higher speed.....and i notice that if i go on a slightly up hill with the gas padel floor or not my speed drops.....and when on a striaght i try to floor it but it still take a while to speed up......anybody know if thats normal for this model or is there something wrong with it.........
Bookmarks
Google
Web AF
