01 civic power locksusmailman956 02-08-2009, 04:56 PM The power door locks quit working on my daughters civic checked fuse under hood it was fine any suggestions Copytech99 02-09-2009, 09:11 AM Will they work with the key at II ?? Can you here any noises when working the lock switch ?? Greenblurr93 02-09-2009, 09:15 AM Did you check the relay?? usmailman956 02-16-2009, 04:30 PM Where is the relay and no I cannot hear any noise when switch is activated with key in any position Copytech99 02-17-2009, 03:44 PM Fuses #16 and #9 in under hood box, Fuse #10 in under dash box. Should be checked. The relays appear to be part of the multiplex unit contained inside the under dash fuse box. Automotive Network, Inc., Copyright ©2012
