Re: 740i overheating
Overheating is a big issue, check the cylinders compression to make shure that combustion is not entering in the water system, this will also show if there is an exess pressuere in the hosses (but when overheating you will always have pressure). Also how is the radiator, do you still have water in it or you have to add all the time. There are some hoses at the back of the angine, they are for the heater core but they often leak.
