Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Astro > M Bodies
Old 01-31-2009, 04:11 PM   #1
USA-1
USA-1 Normal reputation
2000 astro. smelly heat/defrost when on
Hello
2000 astro. I have noticed for the last month when heat/defrost on a bad smell coming out. Smells like cat pee or amonia smell? Also when shut down vehicle or heat I can hear it like garggle on the passenger side floor. I also do not get heat when selected by dial? it either comes out of vent or defrost location. Any help would be greatly appreciated
USA-1 is offline   Reply With Quote
Old 01-31-2009, 06:36 PM   #2
old_master
Advisor/Moderator
old_master's Avatar
old_master Normal reputation
Re: 2000 astro. smelly heat/defrost when on
The smell/noise is most likely a leaking heater core, there is no fix, replacement only.
Air distribution problem is a cracked, leaking, or broken vacuum hose between the vacuum fitting on the PCV valve, (driver side rocker arm cover) and the vacuum check valve under the hood, (passenger side), near the A/C accumulator.
Hope this helps
old_master is offline   Reply With Quote
Old 02-01-2009, 10:32 PM   #3
USA-1
WOW
That sounds expensive? What are we talking $$$ roughly? How long before this becomes a real bad problem? Is it bad to be breathing in that smell?
thanks for your help.
Bookmarks
Google
Web AF
