Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Dodge > Caravan/Voyager
Old 01-31-2009, 12:26 PM   #1
tempfixit
tempfixit Normal reputation
95 heater valve operation question
95 Voyager 3.3 engine 212,000 miles
I know that the heater hose contol valve is controlled by vacuum from the heat control lever.
My question is:
When the lever in the vehicle is set at full heat the heater hose control valve should be at wide open mode. Is the valve at wide open mode when the lever is set to the middle or does the valve adjust to the setting of the lever? (Example = heater control lever at middle, the heater hose valve should be half way open.)
I am thinking the heater hose valve has only 2 settings:
lever all the way to the left = valve closed so coolant does not pass thru heater core.
Lever to the middle or complete right position the valve is wide open.
Am I thinking correctly?
Thanks for input
tempfixit is offline   Reply With Quote
Old 01-31-2009, 08:59 PM   #2
peterjon1
peterjon1 Normal reputation
Re: 95 heater valve operation question
IIRC valve is open unless a/c system is in recirc mode.
Sometimes the little voices in your head have really fun ideas.
peterjon1 is offline   Reply With Quote
Bookmarks
Google
Web AF
