1998 Plymouth Voyager
Google
Web AF
bethanyam
01-30-2009, 01:01 PM
It's been a while since I've been here but you all were such a big help last time I thought I'd try again.
Here's my new problem.
I have new brakes, rotors, tires, and replaced 2 warped wheels.
When I drive down the road there is a lot of noise and vibration. The noise I hear is NOT a popping or clicking, but kinda like the noise of a big 4wheel drive truck with off road tires on the highway. When the front is jacked up the passenger tire spins put the drivers side doesn't unless you turn it with your hand. It will NOT spin when Put into drive. Any ideas? Thanks in advance.
Beth
Bear
01-30-2009, 01:17 PM
Maybe a wheel bearing,. When the bearings really get bad they have a nasty growl or roar. Since the wheel will not rotate I would suspect a wheel bearing, these are hub bearing/assemblies and fairly easy to change out. I just did the two fronts on my '96 and they cost me about $90.00 each.
Google
Web AF
