Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Dodge > Dakota
Old 01-30-2009, 09:57 AM   #1
TBirdEd76
TBirdEd76 Normal reputation
04 Dakota Will Not Start
2004 Dodge Dakota 4.7 V8 with 93,000 miles. Went out this a.m. and she wouldn't start. Tried jumping it with other vehicle, wouldn't even turn over. Dome lights and other interior electronics seem to be working and don't dim when I hit the ignition switch. I initially was thinking battery but now maybe a starter????? Sylenoid??????? Any help is appreciated.
Thank You,
Ed
TBirdEd76 is offline   Reply With Quote
Old 01-30-2009, 11:40 AM   #2
jpb53
jpb53 Normal reputation
Re: 04 Dakota Will Not Start
Starter relay is in the PDC which is in the eng compartment. Pin 30 at the relay should be hot at all times.Pin 86 should be hot when the ign switch is turned to the start position. Pin 85 is the ground from the PCM. Pin 87 is the output from the relay to the starter solenoid. You can pull the relay and the pins should be marked on the bottom side.
jpb53 is offline   Reply With Quote
Old 02-07-2009, 02:13 PM   #3
dakota007
dakota007 Normal reputation
Dodge 99 turn over many times before it starts, sometimes! turn it off it won't start I change the cranckshaft position sensor still not starting. help
dakota007 is offline   Reply With Quote
Bookmarks
Google
Web AF
