1996 Dodge Intrepid ES 3.5 Liter Starting Problems, turns Overirishgift4u2 01-29-2009, 08:29 PM I have this Dodge Intrepid, and it all began with the car dieing out whenever it felt like it, You could be driving fast slow it didnt matter the car would just die and eventually restart. Now since this problem has been occuring all the time lately I finally got it home and it wont start, it turns over but just won't start. OK , the parts I changed because there was no check engine light on, I changed the Camshaft Sensor, the Crankshaft Sensor, and the ignition coil. Does anyone know what the problem might be? I don't want to spend the money on a computer if that is not the problem, I spent over $150 on all the parts and have very little $$$$$$$$$$$ available. Is it possible maybe the map sensor. I had the battery tested and that was all good. I pushed the high pressure fuel pin in and it had fuel coming out but very little , the car was not on. :headshake tempfixit 01-29-2009, 11:55 PM Welcome to AF Remove the air cleaner duct work to the throttle body and spray some carb cleaner at the throttle body and see if it runs More than likely it will stop as soon as the carb cleaner is burned up. If so fuel delivery problem. Test the fuel pressure with a fuel pressure tester. Automotive Network, Inc., Copyright ©2012
