Originally posted by ricecube77
Nono, im not trying to remove the steering wheel cover that contains the key ignition.
I'm trying to remove the black plastic cover that holds the "Security" light to the left of the steering wheel. That cover needs to be removed to get into the cluster lights to change them on a P10 right?
-Phil
Oh, I see ...
Well, it sounds as if you've done things right ... did you lower the steering column?? If you have tilt steering I guess you could lower it that way rather than the way the following procedure states. In any case, here is the Haynes procedure for removing the "Instrument Panel Surround"
"Remove the steering column shrouds as described previously.
Loosen the two steering column upper securing bolts, and lower the steering column slightly.
Unscrew the five instrument panel shroud securing screws. Two screws are located at the top of the panel, two on the left, and one on the right.
Carefully withdraw the shroud from the facia. If necessary, lower the steering column further to provide sufficient clearance."
My manual makes no mention of the "security light", so is it possible that could be what is holding it on??
