Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > GMC > Sonoma/S-15
Old 01-28-2009, 02:04 PM   #1
bnp
bnp Normal reputation
Taking the bed off of 1996 Sonoma
We have 1996 Sonoma that we need to take the bed off of to replace the fuel tank. Does anybody know how to remove the bed or have any advice for installing the fuel tank?
Thanks
bnp is offline   Reply With Quote
Old 01-28-2009, 07:27 PM   #2
brcidd
brcidd's Avatar
brcidd Normal reputation
Re: Taking the bed off of 1996 Sonoma
I take the bed off those trucks to replace fuel pump-- to replace the fuel tank- I would not bother-- but there are 6 or 8 bolts that hold the bed to the frame- I take all those out- and all that is left is the fuel tank filler neck and the tailight wires- which I usually leave attached and just tip the front of bed up high enough to sit on the tire and work on fuel pump- I use an overhead hoist- but it can be done with four people picking it up...if you have enough buddies around...
Automotive A/C Engineer with:
'95 Chev 3500, 454 Dually Crew Cab- 145k miles- Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone- blown head gasket
'92 Chevy Lumina Van 3.8L 264k miles
'86 GMC S-15 - 2.8L 154k miles
'86 Buick Park Ave 3.8L 199k miles- my daily driver
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles- my high school car!!
All but the Camaro and Firebird are white....
brcidd is offline   Reply With Quote
Old 01-28-2009, 08:26 PM   #3
bnp
Thanks for the advice. Even with the fuel pump assembly having to be reinstalled with the tank (sorry i didnt include the pump in the description) do you reccomend doing the work from the bottom? Another question to go with that though is whether or not the truck (a regular 4wd with no lift and stock tires) would be high enough to do the work or if would have to be raised, if so would a regular garage jack and stands lift it high enough, unfortunatly it doesnt currently run because the mechanic removed the previous tank while it was on a lift and it was towed home, so i cant use any ramps.
Thank You for your time and knowledge
BP
Old 01-29-2009, 09:07 AM   #4
brcidd
brcidd's Avatar
I would use a floor jack and lift the truck up high enough to slide the ramps under two front wheels- alternate the ramps so truck won't try to roll off- and then use jack stands for the rear axle. The truck needs to be up high enough to easily slide the tank under -
Since the tank is already off- might as well work from the bottom- nothing saved by taking the bed off now IMO.
Old 01-29-2009, 04:45 PM   #5
bnp
Okthanks
Bookmarks
Google
Web AF
