2006 Grand Caravan Oil Pressure Light
Google
Web AF
BrianP
01-26-2009, 04:45 PM
The oil pressure light comes on when I'm stopped and idling. Shuts off when I accerelate. Any ideas as to the problem? Bad switch maybe?
Any harm driving or should I get it in for service ASAP?
cbwilsha
01-26-2009, 05:37 PM
Have you made sure You're not low on oil?
C.B.
tempfixit
01-26-2009, 05:48 PM
Best if you test the oil pressure with a mechanical gauge in order see what your actual oil pressure is at idle and under acceleration. Best if you service ASAP to prevent engine failure.
Like stated above make sure oil level is correct, if correct I would take to dealer have them check it under warranty. When was last oil change and what oil and filter do you use?
Google
Web AF
