Misfire on cylinder 1dde2 01-24-2009, 06:01 PM Hi Group, I have a 2000 Windstar with the 3.8. I did the Isolator bolt thing a couple of years ago and changed out the EGR valve out at the same time. And up until about 2 weeks ago everything was fine (other then I have to replace the DPFE sensor about once a year) My wife was at the drive through of our bank and the van started running poorly. the check engine light came on and started flashing, according to the owner's manual it means it has a misfire. I had the codes checked and got a "Misfire on cylinder 1" In the past two weeks I have changed the plugs, wires, Coil pack, fuel filter, and the injector for cylinder 1. I get good spark on the #1 cylinder. (Hooked one of the old plugs up to the wire and saw good spark then replaced the new plug with the one I just saw good spark from after checking the gap of course.) A mechanic (A real mechanic not one like me, he has about 30 years experience and is GM certified) put a "Noid" on the electrical connector to the #1 injector and it shows good signal from the computer. While the van is running, I can pull the electrical connection from the #1 injector (just replaced today) and it makes no difference in how the van is running. If I pull the electrical connector from one of the other injectors the engin runs a lot worse so I am fairly confident that Cylinder 1 is the problem, but I cannot for the life of me figure out why it isn't working. I cleaned the EGR ports on all of the cylinders so i don't think that it's clogged.The van is still not running right and I am quickly running out of money and patience. Any ideas would be greatly appreciated. wiswind 01-24-2009, 06:06 PM A new injector on cylinder #1 should be clean, and the unplug test would seem to indicate this injector. However, I would try the Berryman's B-12 Chemtool anyhow.....worth a try as it is possible that some dirt got knocked loose. It is a cheap thing to do, and has helped me with misfire issues a number of times over the years. dde2 01-24-2009, 06:40 PM Thanks for the fast reply, I tried the B-12 trick ( got the idea from this forum) when the van first started running bad and it hasn't been driven more then 10 or 15 miles since (Slowly and with very easy acceleration). I just talked to the mechanic again and he gave me another thing to try. Before i pulled the fuel rail, I tried to release the fuel pressure via the relief valve on the front on the rail. I didn't get more then a few drops of gas out of there and when I pulled the #1 injector i got maybe a teaspoon of gas from the rail there. He said that maybe the fuel pump is bad (since the pressure was so low) and that may be what is causing #1 to misfire. He suggested I spray carb cleaner into the plenum via the rubber coupling between the throttle body and the air filter to see if that stabilizes the motor, if so the van is running to lean and may be the pump, if it runs worse it may already be running to rich and I have no idea what that will tell me. dde2 01-24-2009, 07:28 PM Well, tried spraying the carb cleaner into the intake, didn't seam to make any differance so I have no clue what to try next. discnik 01-24-2009, 08:11 PM Have you done a compression test on the cyclinder ? Compression below 100 psi will cause a misfire. Possible vacuum leak in the area of the #1 cyclinder is another likely cause. One other possibility: You said you replaced the coil pack for that cyclinder, it could be that the module is bad. I have seen this on GM vehicles. dde2 01-24-2009, 10:09 PM hi, Mechanic did compression check, had 125 PSI on the cylinder. I've thought about a vacuum leak from the plenum area, I've taken it off four times, got new Iso bolts and gaskets from Ford. Felt and listened all around it as best I could to feel or listen for a leak. ( I did find one time where i forgot to reconnect the vacuum for the brake booster, got all excited, but it wasn't it.) On the bad coil pack thing though... Wouldn't getting good spark to the cylinder indicate it's OK? I'm honestly asking because I am no mechanic, I just buy the haynes manual when I get a car and pick every bodys brain (like now) when I can't figure a problem out. discnik 01-24-2009, 10:42 PM Sorry missed the good spark part. I take it this is an all the time miss not just when warm or cold ? Have you take a manifold vacuum test ? It is the only remaining thing I can think of. Vacuum should be 19 - 21 inches. Let us know. dde2 01-24-2009, 10:56 PM I read about a vacuum check in the manual, but don't have the equipment/knowledge how to do it. My mechanic hasn't suggested it but I will ask him about it tomorrow. Thanks. 12Ounce 01-25-2009, 05:31 AM You should do a compression test on the whole engine... to compare the cyl #1 to the other cyls. This test is a bit of trouble as all the plugs have to come out at once ... and therefore no one is excited about doing it. 125 psi may be low ... but you won't know until you know what the other cysl are doing. I would expect around 175 psi on each cyl if all is OK wear wise. dde2 01-25-2009, 01:54 PM Well here is the latest. My mechanic called me this morning and said he wanted me to run another compression check on the # 1 cyl. he said that This time I should start the motor, and see what the pressure was, then release the pressure and see what it went back up to. Following these steps, I found that my initial compression was 120 psi, after release it dropped to 0 and would only rise to about 50 psi with reving the engine. he said that means that the valve spring has either cracked or broken, but whatever the case, it is not allowing the valve to seat correctly, causing the mis/no fire on cylinder #1. At this point I am going to tow it over to his place and let him do the work. I will post the final results when it is repaired just in case anyone else comes across a similar problem. wiswind 01-25-2009, 02:46 PM Well, this is an overhead valve motor, so the spring is right there when the valve cover is removed.....and the mechanic will be able to see the rocker, valve and spring easily. It is not a common issue, and I would not have thought of it. Anyhow, it is good that you have something to work with. Fuel pressure issues can be really tough to track down as the OBDII system on the windstar does not monitor fuel flow or pressure. On the 2000 model year, fuel pump and PCM relays have been mentioned, as well as the fuel pump. I would ask your mechanic to check the fuel pressure while it is in......just to be on the safe side. Sometimes the fuel issue can be intermittent....at which point a good move would be to replace the above mentioned 2 relays, and see if that cures the problem before going to the expense (part and labor) of the fuel pump. 12Ounce 01-25-2009, 04:36 PM I have read of some valve spring issues. They must not be very prevalent. Makes me wonder how long I should try to keep my ole Winny ... '99 @ 251k miles now. A valve spring breaking is one of those things that can happen without any warning and there are no preventative measures. wiswind 01-25-2009, 05:50 PM my '96 is at 207K miles. It is just one of a LONG list of things that can "go" at any time.....on any vehicle. dde2 02-02-2009, 10:17 PM Sorry for the delay in the update. I got the van back from the mechanic and he was right, it was a busted valve spring in the #1 cylinder. Total cost for the spring and seal from Ford....$10 + tax. I spent nearly $400 over a 2 & 1/2 week period, but after I got it back I decided it really did need the new plugs, wires, coil, fuel filter.......... I don't drive the van much as it is primarily my wife's "Mom's Taxi" But driving home from the mechanic's, I felt it had much better acceleration then before, and on the hi-way had a lot more passing power. My wife agreed after she drove it. I guess I hadn't realized how degraded the performance had become over the 4 years we have owned it. I guess the main thing to look for in this case is good compression on the first stroke, then little to no compression on successive strokes. I hope this saves someone the frustration that I went through. 12Ounce 02-02-2009, 11:38 PM Sounds as tho you have a good mechanic. Glad it worked out OK for you. wiswind 02-03-2009, 07:23 PM I spent a LOT of time and money tracking down a slight miss.......before it was enough to light the CEL.....and all it was was dirty fuel injectors....a $3 can of the Berryman's was all I needed in the first place. Like you.....I do not feel bad......my '96 was then in REALLY good shape with new coil pack...and a few other goodies. In this economy....a LOT of folks cannot afford to go out and buy another vehilce. Right now....I could...but prefer to put the money into paying extra on my house......so that it will be paid off long before I retire. I figure that I have hung around with you folks so much....and researched the Windstar so much....keeping my long ago paid for '96 going......that I will drive her 'till she pops big time.....and go out and get another....as they seem to be pretty cheap.....and when you understand them......pretty cheap to keep going. And....I AM CHEAP..... Point being......if you are planning to keep your vehicle (which is the best plan in personal finance)....and particularly when your wife/family is driving it.......you are way ahead of the game to have put the routine parts in that you have. These are things that should not come up at the least opportune time......when you are short on money......when it is -20 (F) outside....... to bite you in the wallet. You can feel reasonably good about the vehicle that you have your loved one(s) out on the road in. One thing that I recommend....for those who do not live in an area that has manditory yearly inspections (like Pennsylvania)......going in once a year to have a "safety check" done is a good idea....so that you catch things before they leave you along the road. tomj76 02-04-2009, 06:13 PM Good job finding the problem... I didn't suspect the valve spring itself, but I was going to guess there was a valve problem.... (easy to say now that it's been resolved!) I remember a post here from a year ago where that was the problem. I'm just curious and I don't know if your mechanic told you, but I'd like to know was the spring broken, or was it just weak? Was the problem the spring or was the valve sticking in the guides? dde2 03-24-2009, 08:17 PM Good job finding the problem... I didn't suspect the valve spring itself, but I was going to guess there was a valve problem.... (easy to say now that it's been resolved!) I remember a post here from a year ago where that was the problem. I'm just curious and I don't know if your mechanic told you, but I'd like to know was the spring broken, or was it just weak? Was the problem the spring or was the valve sticking in the guides? Hi again, And once again, sorry for the long delay in posting, I haven't been on here since the problem was resolved. The valve spring was broken, My Mechanic showed it to me when I picked it up. If anyone needs a good honest mechanic in the Arlignton area of the Dallas Fort Worth Metroplex, send me an email and I'll pass along his contact info. Freakzilla69 03-24-2009, 10:12 PM Fuel pressure issues can be really tough to track down as the OBDII system on the windstar does not monitor fuel flow or pressure. On the 2000 model year, fuel pump and PCM relays have been mentioned, as well as the fuel pump. I would ask your mechanic to check the fuel pressure while it is in......just to be on the safe side. Sometimes the fuel issue can be intermittent....at which point a good move would be to replace the above mentioned 2 relays, and see if that cures the problem before going to the expense (part and labor) of the fuel pump. I have been getting a missfire lately, P300 I believe. I also have low vacuum at my manifold which I believe may be due to some clogged or leaky vacuum lines. I plan to replace those this weekend as well as putting on a new set of wires. I was thinking of buying a fuel pressure regulator to check that too and your post got me wondering... What would indicate the need to replace the PCM, assuming low fuel pressure? That thing is expensive! What other relay were you refering too, is there a multi-purpose relay for the fuel pump? Changing the fuel pump looks like no fun whatsoever, if I find that I have low fuel pressure, I'd like try other possibilities first. Is there anything else besides the fuel pressure regulator and the relays? I believe it is my destiny to replace every part on this van, one at a time. I'd like to do the easiest ones first. Captv2k 05-17-2009, 09:41 PM Have you try to flash your computer. I belive I had the same problem b ut it was my number 2 plug that was not firiing up. too many mislead me. untill I took the computer to have it flashed and bingo. It worked just like when I first bought it. It did the work. Let me know, if it worked. SpiderMonkey56 07-18-2009, 03:37 PM I've got the same CEL code. Have tried Plugs and Coil still no better. Just signed up and will try the EGR Valve & DPFE Sensor next. I'm praying it is not valve spring broken on mine! wiswind 07-18-2009, 04:43 PM EGR valve rarely fails on the windstar.....so I would hold off on that. Automotive Network, Inc., Copyright ©2012
