Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Dodge > Caravan/Voyager
Old 01-24-2009, 04:02 PM   #1
samtheman22
samtheman22 Normal reputation
Caravan whining noise
Has anyone had this problem? 2004 Dodge Caravan 3.3 77k..... I hear a whining noise that seems to be coming from the passenger side of engine, but can't pinpoint it exactly. Sometimes it whines sometimes it doesn't , most noticeable when turning and in cold weather. Any help is greatly appreciated, thanks.. Sam
samtheman22 is offline   Reply With Quote
Old 01-24-2009, 05:24 PM   #2
tempfixit
tempfixit Normal reputation
Re: Caravan whining noise
I would say it is the power steering pump making the noise.
Could be a clogged screen in resorvoir, faulty pressure hose or just needs a fluid flush with new atf+4 installed.
Do a search on this forum using power steering fluid change and you should numerous threads refarding this issue with fluid changing procedures.
Also check for TSB's and RECALLs using the online service manual at top of page of this forum.
Good luck and keep us posted.
tempfixit is online now   Reply With Quote
Old 01-24-2009, 08:19 PM   #3
vipergg
vipergg Normal reputation
Yup my vote is on the ps pump. Drain the reservoir and refill with clean atf4 . Drive for a few weeks and change again.
vipergg is offline   Reply With Quote
Old 01-28-2009, 08:28 AM   #4
appstech
appstech Normal reputation
my vote would be check out the alternator decoupler. This model and engine are known for them wearing out.
appstech.
appstech is offline   Reply With Quote
Old 01-28-2009, 08:58 AM   #5
slider1568
slider1568 Normal reputation
I have a 2006 Town & Country and for some reason I have to add power steering fluid about every 6 to 8 months, and I KNOW it needs it when it makes that sound when it is cold. I have no visible leaks and absolutely NO leaks on the driveway, very weird, but everytime that noise appears... power steering fluid is needed.
slider1568 is offline   Reply With Quote
Old 02-13-2009, 08:34 PM   #6
samtheman22
I think I fixed the problem. A guy on another Dodge/Chrysler forum advised changing the power steering reservoir. I did that , replaced the fluid and the whining stopped immediately and so far has not returned. I tore apart the old reservoir and found a plugged screen, so I am thinking that was the problem. Total cost about $25 and took about 45 minutes to replace.
Old 02-13-2009, 11:22 PM   #7
hundahunta
hundahunta Normal reputation
yes there is a bulletin to change to reservior for a moan/fog type noise.
hundahunta is offline   Reply With Quote
Old 02-21-2009, 11:24 PM   #8
tengger
tengger Normal reputation
also check ps hoses. there is a section on both high and low pressure that is rubber hydrilic hose. 15 bucks for a 3 ft piece you need 6in for each. or 70 or so dollars per line.
tengger is offline   Reply With Quote
Old 03-30-2009, 05:30 PM   #9
Ricki
Ricki Normal reputation
Smile Re: Caravan whining noise
I have a 2004 Dodge caravan. It was whinning first thing in the morning whe the engine was cold. Once it warmed up the whinning of the power steering stopped. I did as was posted here and replaced the reservoir and that fixed the problem. Thank you all. This has saved me hunderds of dollars in repair cost. To placed the unit only took about 1 hour and cost about $40.00 from the dealer.
Ricki is offline   Reply With Quote
Bookmarks
Google
Web AF
