Another Cold weather starting problem
905ln
01-22-2009, 07:39 PM
Hi all
New guy posting
Great site, very informative
2000 Jimmy, 109500 mi. Cold weather starting problem.
Followed MT advice and pressure test the fuel pump. Here are the results.
Key on not started 60 psi
Engine started idling 58 psi
Pinched off return key on not started 64 psi
Driving & accelerating between 56 & 58 psi
I guess the readings speak for them selves. Change the fuel pump?
What seems funny is that the truck starts no problem above 14’ F. Anything colder and I have to plug in the block heater I assume to keep the injectors warmer. If any one has any other suggestions please let me know.
Thanks
tempfixit
01-22-2009, 09:06 PM
Which engine?
How old is battery??? On my 96 k1500 5.7 if I don't have a good battery with high cca (Right now I have a 630 cca battery ) it won't turn over fast enough in cold weather for the injectors to fire.
When you plug yours in the engine block gets warm enough so its easier to crank over fast enough to fire injectors.
Hope this helps
Scrapper
01-22-2009, 09:36 PM
i would try a good battery because when your cranking it takes power from pump and your battery is doing this that should be plenty of presure to start it. i have a duralast in my truck for about six years now. and it will start like your saying the colder it gets it wont start and when it gets warmer it will start. so i'd start with a higher cranking amp than what you got now and a well knowen battery. i'll tell you now not a sears sucker..
