How to eliminate squeak inside passenger area during driving
Shmith
01-19-2009, 04:21 PM
I have older car, everything fine except squeaking inside passenger area when during driving
I think it comes from friction of plastic inside saloon for example between drivers door and dashboard area its gone when i push at that place with my fingers. Bolts are screwed tight so i dont know how can it happen.
Someone have any idea how i can eliminate this and other possible sources of squeaking sound its really annoying, is there some compound or spray that i can use?
Scrapper
01-19-2009, 04:53 PM
have you checked the door pins also does the door latch all the way? if so look at where it latches on the body of the car and see if the doors out of alignment. only other thing to tell you to take door panel off and inspect all your gagets in there and take penatrating oil and spray it good. with door panel off take it for a drive with someone in there and see where the squeak is.
Blt2Lst
01-20-2009, 06:09 PM
If you can't quiet the squeek, just turn up the radio volume and forget about it :evillol:
bobss396
01-30-2009, 12:36 PM
I had a '64 Olds 88 with a squeak between the dash and windshield. I folded up a piece of cardboard and wedged it in between and it worked fine. Until a passenger once said "what's this?" and pulled it out on me!
Cheap and easy, maybe not a permanent fix.
Bob
