had spark plugs changed ...now wont start
trippy02
01-19-2009, 03:03 PM
hi i had my plugs changed, and since then it was hard starting, engine light is on and occaisionally (3 times now) my hold light was on and flashing...it takes quite a few tries to start it , its turning over but not starting...now i can hear the battery draining and it wont start at all...help
LMP
01-22-2009, 01:03 PM
Why did you have the plugs changed in the first place? Was is just planned maintenance, or was there already a problem you wished new plugs could solve?...and how long was the time between the plug change and the presnet condition ?
cd09
01-24-2009, 01:29 AM
did you get your coil wires switched up?
Jasmine1998
04-11-2010, 09:45 AM
just went through this myself... I had to change the ignition coils on my kia. I changed the plugs and ignition wires it would start but no power at all had a friend bring his machine over and it ended up being the ignition coils 2 and 4 wasnt getting nothing. once I changed this and put everything back for the 100th time it cranked and ran beautifully
This was the first time I had ever done the spark plugs on a car much less on a Kia. and I went ahead and changed valve cover gasket, ignition coils and plugs and wires. from now on when I need to change plugs I will make sure I buy the ignition coils, gaskets, plugs, and wires before doing anything. my next project on my Kia is changing the motor on the passanger's side for the window.
