no fuel on start up
Dirt_Bag2009
01-19-2009, 01:44 PM
GA_googleFillSlot("Forums_ROS_300x250_noad");Hi all new to forum.
I have a 89 S10 4.3 tbi 4x4 truck
I got the fuel pump for 2 sec when I turn key to on
but when motor is cold I need to pump the gas to get the injectors to pump fuel?
but when its warm it fires right off?
It all started when I changed my heater core and themostat.
I loosend my dash and pulled it out a bit on the passenger side.
I have replaced:
fuel pump relay
ignition module
Is there a ground strap I may have off in the dash area? Is there a ground strap for the ecm?
It runs great once started. it goes down the road fine even freeway no fuel starvation
MT-2500
01-19-2009, 01:50 PM
Check the thermostat bolt grounds and the tempt sending unit to computer and also the air intake sensor for being plugged up.
Dirt_Bag2009
01-19-2009, 02:16 PM
Every thing was fine untill the heater core tho. I have ran another ground on the wires that go to the stud.... No change
Could I have plulled off a ground wire by the heater core? or is there any there?
The only wires I unplugged were the two ecm and that 1 plug that hooks into that white thing that attaches to the ecm bracket
Dirt_Bag2009
01-19-2009, 02:22 PM
It will start to pump if I pump the throttle to the floor?
Dirt_Bag2009
01-19-2009, 03:12 PM
I just tested again and it is a code 54 fuel pump relay. It has had this code from the time it has started this problem?
MT-2500
01-19-2009, 03:46 PM
Check for and check all ground wires on stat housing?
Will code clear and come back or not come back?
MT-2500
01-19-2009, 04:09 PM
Does fuel pump run on engine cranking?
How is the fuel pressure?
