DTC P0748 2001 Voltswagen VW Cabrio Automatic TransYYeahoo 01-17-2009, 10:35 PM 2001 Volkswagen Cabrio 2.0L I4 EFI / MPI 4 speed automatic 112000+ miles The check engine light came on and the transmission is stuck in the third gear. Scanned the code and it gave me P0748 "Pressure Control Solenoid Electrical". The display on the dash that shows what gear you are in (P R N D 3 2 1 ) is intermittently all lighted up and does not tell you what gear you are in. Also If I clear the DTC P7048 it seems to shift ok for a short time...but soon sticks in 3 gear. The Check engine light may not come on until the car ignition is cycled. I have checked the Tranny fluid and ok. Doesn't look like any damaged or oil soaked wiring. I assume this "Pressure Control Solenoid" is inside the transmission. Does anyone know what wires or how to test a Pressure Control Solenoid? Does anyone Know where I can find Electrical schematics for the 2001 cabrio? I have a Haynes repair manual but not much info on Tranny wiring. Thanks :screwy: *Andrew* 03-26-2009, 12:09 PM YYeahoo (http://www.automotiveforums.com/vbulletin/member.php?u=600814), I have the same problem, it has been a while since your post did you make any progress in fixing this? Also can you point me in the direction that fixed it for you, thanks. vBulletin®, Copyright ©2010, Jelsoft Enterprises Ltd.
Automotive Network, Inc., Copyright ©2010
