Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Dodge > Caravan/Voyager
Old 01-17-2009, 09:55 PM   #1
parvatsagar
parvatsagar Normal reputation
99 T&C hard to start in cold but unstable idle and die out run ok in warm or hot days
Guys, I have 99 T&C for 9 yrs now and seems to be from summer i get this problem
#1 Once i had unstable idle and cuttoff after highway driving in august (warm month )
Check complite vacume system and gas line and return becuse of code
Fix was clean IAC and put back added chevron engine cleaner (recomended by mechanic)
work good
then
#2 soon as nov dec 2008 came proble came back
unstable idle when cold, start car but not stay on till hold gas padle to keep it on
fix was low battry cold crank amp ( was not an real issue)but considering chicago winter was wise thing to do ...problem not fixed
then i search around and came accross this site ..good info intaligent people and appriciated
fix narrow down to coil pack drop when extreamly cold days range should be 10900 to 14900 i got ok in 40F( 12000) but in cold -10 left it 2 hrs (new pack and old pack and measure resistence ...2 coil got around 109XX and one got 10700
Improoved idle but car was parked at 40F so unsure
then got idle air control and put it in drive out and park out in cold for 6 hrs
car started idle started with 1200 and slowly came down to 900 after 2 mint s
specially thanks to RIP
appriciated all forumes and i went thru about 30 diffrent to narrow down
thanks again
i will update if any thing changes
parvatsagar is offline   Reply With Quote
Old 01-18-2009, 03:03 AM   #2
RIP
AF -Advisor
RIP's Avatar
RIP Normal reputation
Re: 99 T&C hard to start in cold but unstable idle and die out run ok in warm or hot days
Not sure what I did but, thanks for the thanks. While I'm at it a big thank you to you for passing your experience along. Hope your troubles are over.
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
**DIYer and multiple automotive forums junkie for years. Air Force career in aviation electronics.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan / 94 Camry
RIP is online now   Reply With Quote
Bookmarks
Google
Web AF
