Head Gasket Leak or LIM Gasket?Bozly 01-17-2009, 03:34 PM We have removed everything down to the exposed heads. After removal and inspection of the plugs, I dont think its the head gasket but the LIM gaskets. Is this a common problem? Thanks, Mark Blue Bowtie 01-17-2009, 10:28 PM On the 60º V-6 engines, the aluminum surfaces can deteriorate and allow leakage. They are repairable. http://www.finemotorcars.org/files/191CIDIntakeFlangeErosion.jpg Bozly 01-18-2009, 01:10 AM Could this be repaired without removing the head? Blue Bowtie 01-18-2009, 01:58 AM If the eroded/pitted area is thoroughly cleaned, it can be filled with a metal-bearing epoxy. Once the epoxy is cured it can be scraped flat treated like metal. This one has lasted since February of 2006: http://www.finemotorcars.org/files/191CIDHeadFlangeFinished.jpg wafrederick 01-18-2009, 06:44 PM It is a common problem and get the Dorman kit which is complete with new bolts.The intake gaskets from the kit are made out of metal instead of the crappy plastic GM uses vBulletin®, Copyright ©2010, Jelsoft Enterprises Ltd.
Automotive Network, Inc., Copyright ©2010
