2000 blazer vibration problemdjjm3 01-15-2009, 12:00 PM I have a 2000 blazer with 204,000 miles on it. I get vibration at 50 mph.....any reason? MT-2500 01-15-2009, 01:12 PM More info would help. 50-60 MPH vibertion is usually tires and wheels. Have you got mud on wheels? Slipped belt on tire? Bent wheel? Have you had tires balanced? tempfixit 01-15-2009, 01:18 PM I have a 2000 blazer with 204,000 miles on it. I get vibration at 50 mph.....any reason? Inspect all front end parts, tie rod ends, ball joints, idler arm, etc. What condition are the tires? Check u joints on drive shafts. Do you feel vibration on steering wheel or any where else? djjm3 01-15-2009, 02:03 PM More info would help. 50-60 MPH vibertion is usually tires and wheels. Have you got mud on wheels? Slipped belt on tire? Bent wheel? Have you had tires balanced? No mud No bent wheel They was all balance Slipped belt don't think so djjm3 01-15-2009, 02:15 PM Inspect all front end parts, tie rod ends, ball joints, idler arm, etc. What condition are the tires? Check u joints on drive shafts. Do you feel vibration on steering wheel or any where else? Vibration is everywhere.... Tie rod was replace 20,000 miles ago. Back tires are due. I was thinking u joints... MT-2500 01-16-2009, 09:51 AM Proper inspection and a good description and more information would help. Has it been raised or lowered? What all speed does it do it? What speed does it do it more? In 2W or 4W? What all service work done? Did it start all at one time? Have you inspected U jounts and drive shafts? Have you double checked tiresand wheels? Does it do it on coast or pull or steady down the road? Does turning wheel left or right when going down the road change noise? djjm3 01-16-2009, 10:10 AM Proper inspection and a good description and more information would help. Has it been raised or lowered? What all speed does it do it? What speed does it do it more? In 2W or 4W? What all service work done? Did it start all at one time? Have you inspected U jounts and drive shafts? Have you double checked tiresand wheels? Does it do it on coast or pull or steady down the road? Does turning wheel left or right when going down the road change noise? -19 degrees today ...I couldn't get under the car......it dosent pull left or right....it happens in 2wd.only happens between 50-60 mph......over and under that speed smooth as the road conditions its rolling on....tie rods replaced on both sides....it happened all of a sudden.....happens coast or accellaration between 50-60 mph...... MT-2500 01-16-2009, 10:14 AM 50-60 MPH vibration is usually wheels and tires. Have them double checked. MT-2500 01-16-2009, 10:18 AM One good test is to jack it up put rear axel on stands and spin rear tires at 50-60. If 4W do same with front end. AJT1961 01-16-2009, 04:45 PM When my 2000 Blazer developed a bad front end vibration at about 50mph it turned out to be bad ball joints. First I balanced the wheels which helped (vibration then happened at a higher speed), but the problem didn't totally disappear until I replaced the upper and lower joints with some quality Moog parts. If your ball joints are original equipment (If they are riveted in place) they are probably on borrowed time anyway. djjm3 01-16-2009, 09:08 PM When my 2000 Blazer developed a bad front end vibration at about 50mph it turned out to be bad ball joints. First I balanced the wheels which helped (vibration then happened at a higher speed), but the problem didn't totally disappear until I replaced the upper and lower joints with some quality Moog parts. If your ball joints are original equipment (If they are riveted in place) they are probably on borrowed time anyway. I did the ball joints and tie rod ends at the same time....steering wheel dosent shake...Its coming from the back...was thinking about tire rotation.... ktl4974 01-17-2009, 08:49 AM Same problem w/ my '99, it ended up being u-joints. I replaced all and have had no problem. djjm3 01-17-2009, 12:12 PM Same problem w/ my '99, it ended up being u-joints. I replaced all and have had no problem. Did yours "clunk" when u put the car in gear? I know thats the "Old School" way of knowing if u-joints was going... djjm3 01-23-2009, 09:04 PM More info would help. 50-60 MPH vibertion is usually tires and wheels. Have you got mud on wheels? Slipped belt on tire? Bent wheel? Have you had tires balanced? MT - 2500 was on the money (Thanks!)... 2 back tires out of balance! wound buying new ones.....Rear U Joints was Ok.... MT-2500 01-24-2009, 09:25 AM You are welcome And thanks for posting back the fix. Glad you got it fixed. Good luck Automotive Network, Inc., Copyright ©2012
