Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Ford > Contour
Old 01-14-2009, 11:15 AM   #1
2000contourx
2000contourx Normal reputation
Code/fix help please
hi, I have a 2000 contour SE v6 and recently have had trouble with iradic idle and when left it will stall or when your driving and have to stop it will stall also. The check engine light has come on with the rough idle,it has a few codes p0171, p0174, p0301, p0303, p1131, p1151. Thanks
2000contourx is offline   Reply With Quote
Old 01-14-2009, 11:26 AM   #2
Airjer_
Airjer_'s Avatar
Airjer_ Normal reputation
Re: Code/fix help please
As soon as I see the 171 and 174 (lean bank one and bank two) I immediately go fro the smoker to check for vacuum leaks. The ruff idle and stalling you described are also classic symptoms. You can carefully spray carb spray (it is flameable and it can start a fire) around the intake/plenum and see if the idle changes if it does the gaskets under the plenum are leaking.
Airjer_ is offline   Reply With Quote
Old 01-14-2009, 06:24 PM   #3
beyondloadedSE
AF Ford Contour-Advisor
beyondloadedSE's Avatar
beyondloadedSE Normal reputation
If I had to guess, your upper intake manifold gaskets are breaking down and leaking. I would replace both the upper and lower intake manifold gaskets and see if that fixes the problem. Also check the throttle body gasket for leaks, PCV system hoses connecting to the rubber accordian tube, and the rubber hose connecting to the 3/8" brass tube on the lower side of the upper intake manifold.
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
beyondloadedSE is offline   Reply With Quote
Bookmarks
Google
Web AF
