Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Engineering/Technical
Engineering/Technical Ask technical questions about cars. Do you know how a car engine works?
Old 01-14-2009, 12:11 AM   #1
RmBond
RmBond Normal reputation
99 silverado low oil pressure
I have a 1999 silverado 1500 with a 5.3 Im having oil pressure problems when cold the pressure runs about 40 while driving and idiling but once the truck gets warm it goes to about 30 while driving and 0 while idiling, but if you barley touch the gas not even 1000 rpm the pressure jumps to 20 while in drive. but if you put it in park it goes to about 20 any suggestions or information would help.
Thanks,
RmBond is offline   Reply With Quote
Old 01-14-2009, 09:14 AM   #2
brcidd
brcidd's Avatar
brcidd Normal reputation
Re: 99 silverado low oil pressure
Most oil pressure "problems" are in the sending unit- you have to be able to trust your gages- so best thing to do is plumb in a mechanical gage to know what the real pressure is. You can "tee" it in to see if the two pressures correlate. I typically would not believe the "zero" pressure reading- based on your description.
If the gage is erratic- or sits at zero a lot- then I would replace the sending unit- either way, this gives you a place to start.
Automotive A/C Engineer with:
'95 Chev 3500, 454 Dually Crew Cab- 145k miles- Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone- blown head gasket
'92 Chevy Lumina Van 3.8L 264k miles
'86 GMC S-15 - 2.8L 154k miles
'86 Buick Park Ave 3.8L 199k miles- my daily driver
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles- my high school car!!
All but the Camaro and Firebird are white....
brcidd is offline   Reply With Quote
Old 01-14-2009, 09:54 AM   #3
MagicRat
98% argumentative...
MagicRat's Avatar
MagicRat +50
This kind of oil pressure drop is common in higher mileage engines. It is usually caused by a worn oil pump, worn bearings (excessive clearance) or a defective oil pressure relief valve.
The idea here is to see how much of a pressure drop you have Stock gauges are not particularly accurate. Install a good quality mechanical pressure gauge and observe the pressure.
The rule of thumb for older engines is a minimum of 10 psi for every 1000 rpm., up to 35-40 psi or so. But a bit more than this is better.
What kind of oil do you use, 5W-30?
You can increase pressure a bit by going to 10W-30 in winter and 10W-40 in summer.
"We' re all here because we're not quite all there."
"I refuse to prove that I exist,” says God, “for proof denies faith, and without faith I am nothing". – Douglas Adams
MagicRat is offline   Reply With Quote
Old 01-15-2009, 04:23 AM   #4
UncleBob
AF -Advisor
UncleBob Normal reputation
stupid question. Is there oil in the engine?
life begins at 10psi of boost
Three turbo'd motorcycles and counting.
UncleBob is offline   Reply With Quote
Bookmarks
Google
Web AF
