changed tie rod wheel still shakeoffroadjoe 01-13-2009, 10:52 PM the front end of my 95 civic shakes when i drive. i changed the right and left tie rod the passenger side is fine no play in the tire. but the driver side the wheel shakes side to said? ball joint> thats what i'm thinkin but please help and if it is the ball joint how do i change it? kris 01-14-2009, 12:06 AM Could be ball joint, or wheel bearing. The bearing usually is accompanied by metal rubbing sounds. hundahunta 01-17-2009, 02:39 PM are you changing the inner or outer tie rod, you cant check ball joints like that.. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
