4wheel drive not workingmrsbb 01-13-2009, 04:43 PM heres the deal 2002 durango--hubby put new alternator on, (no he didn't disconnect the battery cable first) touched a wire and sparks flew and now 4 wheel drive light is out and my -service 4 wheel drive-- light is on. Took it to a garage today and they can't find the problem yet. Thought it was just a fuse, checked something else to but nothing. Gotta bring it back in to see if its a modular. Any other ideas of what to check. After the garage had it the --service 4 wheel drive -- light is not on anymore. Would disconnecting the battery cable reset the computer ?? Not sure what to try. dcx96 01-19-2009, 06:58 PM had a similar problem too, my service 4wd lite appeared sat nite dealer found that engagement motor took a dump. mrsbb 01-19-2009, 07:31 PM thanks for the info--was it a costly repair??? or something a person could fix themselves or was it a HAVE to take it to the dealer deal??? wonder where it is located?? under dash or under hood? jg09 02-05-2009, 04:59 PM If it's anything like the old Ford Explorers were (very, very common problem), it's something you don't want to replace yourself unless you have some serious wiring skills. I'm speaking for Explorers, here, but I believe it was around $400 for parts and labor to fix mine. Probably about the same for the 'Rango. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
