Re: Door latch
I'm guessing you've done the repair by now but just in case or to help others with this problem which seems to be somewhat common, even though I can't find it in a search, I seem to remember other posts about it.
There is a small plastic connector behind the door handle that breaks. I think I had to go to the dealer for the part. If I remember right I didn't have to remove the door panel entirely but it was a pain working in the tight space. Just pull out the door latch handle & you'll probably see part of the broken piece still connected. It would be a breeze if you remove the door panel but I have crank windows & didn't mess with removing the window handle.
