Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Dodge > Caravan/Voyager
Old 01-12-2009, 01:28 AM   #1
wingman122
wingman122 Normal reputation
01 dodge grand caravan accelerator problem
My accelerator at times sticks and I have to mash down on the acc. to get the van to slow down. any ideas on what can cause this to happen. could it be the accelerator cable?
wingman122 is offline   Reply With Quote
Old 01-12-2009, 01:41 AM   #2
discnik
discnik Normal reputation
Re: 01 dodge grand caravan accelerator problem
First I'd remove the air cleaner tube to your throttle body and check to see if there is a build up around the throttle plate. Give this area a good cleaning. If this does not help visually check the operation of the cable while someone works the pedal, WITH THE ENGINE OFF!!!!!!!!!!!!!!.
Hope this helps.
discnik is offline   Reply With Quote
Old 01-12-2009, 02:37 AM   #3
Rawtorque
Rawtorque Normal reputation
Exclamation Re: 01 dodge grand caravan accelerator problem
It could be the cable getting gummed up with hardened grease & dirt.
BUT; A broken motor mount can also do this.
This is a VERY dangerous situation you have there!
Rawtorque is offline   Reply With Quote
Old 01-13-2009, 11:39 AM   #4
wingman122
discnik...thanks for the tip. You were right on the money..The van is running good now
Bookmarks
Google
Web AF
