abs light and brake light r on?birar 01-12-2009, 12:29 AM i have a 97 and a 95 gmc sierra and on both trucks the abs and the brake lights r on i was possibly thinken a speed sensor? rockwood84 01-12-2009, 10:58 AM or a shorted right brake light board maxwedge 01-12-2009, 05:09 PM Many things can cause this a scan for abs codes is the starting point, just check the rear abs connections first and any other connections in the circuit look for corrosion in particular. Jason241987 04-17-2010, 10:48 PM for the abs light on you might just have a fuse out an under your brake petal is i guess called your brake sensor not sure but you might need to replace that.. quick69gto 04-18-2010, 02:46 PM Or it might be as simple as checking the brake fluid level. rjinmt 05-06-2010, 04:55 PM check the wires behind your brakes on each tire and make sure that there is no worn wires or broken wires. birar 05-06-2010, 05:56 PM i checked all that i think i found the problem now its been good now no light.... the fuse sockets are worn out so i bent the tab on the fuses and they fit snug and work great thanks for the feedback guys! Automotive Network, Inc., Copyright ©2012
